Re: Looking for some peice of mind
The next time you take your boat out I'd add X-tra oil to the tank to make the engine run a litttle "wet". When you ran it with out oil very likely you transferred some piston aluminum to the cylinder walls. By running a heavier oil mix it will help wash those metal particulates out when they let loose. I've don'e this a few times on smaller engines that leaned out cuz the carb jet whent out of adjust ment due to vibration. Still using those endgines after a few years. You might get lucky.
If your regular mix is 50:1, mix it 25:1.
