On mine I found a hairline crack in the feed tube between the pump and the carb inlet, about a 6" long tube with a screen in it.
It was very hard to see any issues but once I moved the tube it broke a part. The tube was very hard and brittle.
I believe the crack allowed a small amount of air to be drawn in.
Might not be your problem but it is a place to look.
Good luck.
