GaJeff
- Joined
- Jul 9, 2012
- 149
Hey guys,
Just finished up a 100% rebuild on my 81 120. It's running great at idle and does a pretty good job when under a load but it does seem to be low on power. I ran it on the test stand for 2hrs with no problems. Broke in the cam at 1500 rpm for 30mins of that 2hrs and varied the rpm the rest of the time, no load of course.
I put it in the boat and it was doing good just a little slow towards the top end and kind of stumbles when I slow down from plane around 2400 rpm and below. I double, triple checked everything. Timing is correct and advances like it should. Dwell is within spec. I checked the carb while underway and it seemed to be a little rich. I adjusted the float and checked needle and seat. I ended up swapping from #52 jets to #60 jets. Its not stumbling anymore and is running fine all the way through the rpm just seems low on power.
Before the rebuild I had accelerator pump problems so i rebuild the carb then and it ran great with plenty of power and 4500 rpm. A hole in my riser is what caused the rebuild. So fresh engine now but low power. I'm only running 38-4000 rpm now.
Do I need to break this engine in more before I will see more power or is something else possibly wrong? I have 4.7hrs on it so far.
Thanks Jeff
Thanks Jeff
