lmorefield41
Thread starter- Joined
- Oct 9, 2011
- 103
I've adjusted both cables numerous times, and I just can't seem to get it right. My problem is that when I try to shift the drive either forward or in reverse, the gears crash for a second, then engage, easier forward then in reverse. The shift cutout switch barely engages either way. When shifting, I can hear clicking like the gears are trying to engage, then they actually engage. I know this isn't healthy for the gears. I've followed how to adjust the cables to a T. It seems as if the lower cable isn't creating enough tension to activate the cutoff switch so the gears can properly engage. Does this sound like a stretched lower shift cable to you guys? If not, what do you suggest? The engine is a 1985 Mercruiser 140hp, 3.0.
