i replaced the water pump on my 87' 115 horsepower mariner and now it makes a clicking noise when i turn my prop and it doesnt go into neutral. It only turns clockwise.
You likely need to take the lower unit off again and manually make sure the lower unit is in neutral and make sure your shifter is also in neutral and reassemble. That should fix your problem.
