Lower unit clunk
Blurb
When I twist the U joints after separating from transom there doesn’t appear to be any playin the actual u joints. No noise and they turn smoothly. However there seems to be a bit of dead space with a clunk in the lower unit near the prop. Is this normal or should I be scared?
Here is a video of the movement and the sound.
Stern drive serial number on the upper unit is OL127946
  • IMG_4024.MOV
There is nothing abnormal about hearing a clunk from the gears, there is a small amount of space between the gear teeth. When running you should only hear noise when going in and out of gear
Blurb
Thank you for the advice appreciate your assistance!
