lower unit on 2003 merc 250
skillman
Just got finished changing lower unit oil and noticed a very small amount of water intrusion, could this just be condensation from sitting all winter? And if i run the motor on the muffs & check the fluid again will i be able to tell if water is getting in there, or will i have to run it in the water? Thanks
Don S
Re: lower unit on 2003 merc 250
Hard to say if it's condensation or not. I doubt it. Have you been replacing those paper gaskets on the drain and vent plugs each time?
A pressure and vacuum check (When the lower unit is empty) will verify if there are leaks or not.
skillman
Yep, i replace the little gaskets every year
skillman
Can i still run it on the muffs to see if water is getting in there?
