MNhunter1
Thread starter- Joined
- May 12, 2014
- 1,141
Why is that? I used a hydrofoil first on my Mercury 175EFI and then on my Yamaha F200. Worked extremely well. Great bang for the buck. I did modify mine so that it was clamped on such that I did not have to drill holes. Did that so that if it did not work I could remove it.The Holes can certainly be filled with JB Weld(Always gives me pleasure to see any and all of those Whaletale things tossed). As for the second Motor with the damaged AV Plate, it appears to me that Metal forward of the Damage, is bent upwards a bit. That should be Straightened, as the Curvature can cause Water to curl up, instead separating cleanly from the AV Plate as intended. A Welder, skilled in working on Aluminium should be able to do fix that, and also rebuild the missing Metal
I had one on my Honda 15 hp with a tunnel hull for the prop, worked awesome.Why is that? I used a hydrofoil first on my Mercury 175EFI and then on my Yamaha F200. Worked extremely well. Great bang for the buck. I did modify mine so that it was clamped on such that I did not have to drill holes. Did that so that if it did not work I could remove it.
We have two good sized Marine stores in my area that sell and service the more popular brands of outboards. Both have signs on the wall that states use of an add-on Hydro foil could void your factory warranty! My wife's sister in law used to work at a major/popular health insurance company. When claims were filed, they were to deny the claim at least twice to see if they would try again. Often after two denials, they stop filing the claim. After 4x they would pay the claim.
