lower unit seals replacement 120 johnson
rick fox
i was told the seals needed replaced as it was seeping some water into the gear case . i bought the seals and am starting into it i have pulled the 4 bolts out that were way down in there . does the intired shaft houseing unscrew to get it out . it looks to have thead's on the outer houseing and it must take a special wrench to do this ?
rick fox
Re: lower unit seals replacement 120 johnson
it is the drive shaft seals i need to replace i think ? not sure if i saying any of this stuff right
ezeke
The drive shaft seals are located in the bearing housing. (Click the thumbnail, please.) You will need to unbolt the housing and slide it up and off of the shaft unless you have the special tool to remove the seals in place. The bearing housing is sealed in place by large o-rings.
You can use the BRP parts catalogs to help with assembly: http://shop.evinrude.com/
Click the diagram in the upper right corner of the linked page, then navigate to your model.
Photo compliments of forum member kenmyfam.
rick fox
i stated it wrong it is the seals in the bearing houseing i want to change , and wondered if the houseing is supost to unthread from the lower unit case?
