lindy46
Thread starter- Joined
- Nov 27, 2008
- 3,886
Last winter, I replaced all the seals in my 1957 35hp Lark. Pressure tested OK. Filled it up with gear oil and put it in the water in the Spring. Just pulled it out of the water, and drained the L/U. Oil was real milky! Pressure tested it again for 3 hours and it held 12psi. I turned the drive shaft, prop shaft and moved the shift rod, and it still held pressure. Strange - water is getting in somewhere, but the seals hold pressure. I'm wondering if it would be better to fill the L/U with a light grease like Lubriplate 105? Early Mercs used this grease due to their notoriously bad seals. Anyone know if it would be OK in my Evinrude?
