cropduster21
- Joined
- Oct 13, 2008
- 24
I would like to know the hole diameter of the main jet on the 9.5 hp motor.
I am going to try and clean my main jet without removing it from the motor. I dont want to disturb the gasket and seal I have on the bottom of the carb. I have the carb bowl soaking with an ounce of carb cleaner (top of carb removed. no plastic in soak) after soaking I will remove the drain plug and I want to push a wire through the main jet which is obscured by the lower cowl of the motor. If I know the diameter of the hole I can push a wire through. PS. I have mikes etc. to measure my wire.
thanks for your help. this thing is driving me nuts but I think I am gaining on it.
