Here is the shortened version of my awful situation...
Last year in April I purchased a 96' 250CR Crownline (454 7.4L Merc / Bravo 2) for X-dollars w/ trailer. Good deal, low hours (340) and ran solid for all last season and up thru this season until 2 weeks ago. Engine was impecable or so it would seem.
I stalled on the water and lost shifting capabilities. Well, I had it pulled and gave it to the marina for inspection. Upon their review here is what they found...
1) Upper vertical shaft in drive is sheared off. Metal has contaminated the upper gear set and has caused damage in upper gear housing. Recommend a re-manned upper from Merc
1a) Upper bearing on lower vertical shaft are fouled with metal particles from failure. Lower shaft, bearings and gears all look okay.
1b) Recommend re-man upper
1c) Replace fouled bearings in lower, re-assemble with new seals, load rings, tab-washer, retainer nut and skims. Re-fill with gear oil, lube u-joints, ect...
2) Gimbal ring and pin is very - very loose. Bellows are cracking
2a) Repair / replace gimbal ring, pin, arm (if needed) and perform full boot job with gimbal bearing, intermediate shift cable and senders. Hi-performance exhaust boot per discussion with customer.
2b) Full boot job
2c) Gimbal ring, shaft and lever
2d) Sender kit
2e) Shift cable assembly
3) Rear engine coupler is very worn and if major overhaul is done it is highly recommended to replace. It is economical to proceed with this.
The total for these jobs = $9,372
First and foremost I am devestated facing these issues but once I settled down and realized there is nothing gained with anger and frustration I came up with a few questions...
1) Are these charges in-line with fair market price?
2) Can any of these items be put off or are they all needed?
2) Is it worth sinking $9k or cut losses and try to sell it? I am very defeated after this experience and really have lost enjoyment. How would someone go about selling a boat needing major repairs?
3) Would there have been any way of foreseeing all these problems. Would a surveyor have pulled the outdrive apart or inspected engine coupling? I bought the boat from a very trusted individual and couldn't imagine him knowing of the major issues (the boot job was obvious but MINOR in the grand scheme of things).
4) Is this throwing good money after bad?
Thanks everyone for taking the time to review this long email and resonding with ANY help / suggestions.
Your defeated fellow boater,
Jc
2b) Full boot job
2d) Sender kit
Jc
