truckermatt
- Joined
- Mar 29, 2009
- 384
Re: Making my trailer more heavy duty
How would there be 3600lbs on the axle.....
I weight at an axle only scale.... some of the weight is on the truck side also....
I drive semi trucks for a living, and i know the weight get distributed over all the axles.... not just the one the the load is "on"
either way, I will continue to use the trailer as is.... If i find a cheap tamdem axle over winter i may fix it up and use it....
You are close, but should be OK. Although, the 3500# axle (while supporting only 3300, you are really weighing 3600, 100 over the axle rating...
Additionally, the downward force on the spindles with traveling is multiplied by X factor over the 3300 current axle weight...
JMHO, If it were me, I would feel better with the 5500 axle. But you are only over slightly so it is your call...
