clevecan
Thread starter- Joined
- Aug 25, 2008
- 130
Hi all, I was ajusting my shift and throttle cable and I seen that at full throttle my carb blades are only 5/8's open.
so I removed throttle cable and ajusted it to where the carb. blades were open 7/8's not all the way to stops on carbs
not wanting them to hit and damage them,then I pushed throttle to WOT and it went to where I set it.BUT! once I pull throttle
back to idel it seems it is not returning all the way back on it's on. I removed the cable again and seen that if I try to move the end
of the cable it will move about 1" back and forth but throttle arm benical is locked in Neutral, once I push to WOT and back to neutral
and remove the cable I can by hand push linkage back to idel, So it seems that the cable has slack in it. with cable off linkage I can push or pull
1" of slack??
1987 200 HP Mariner carbed,
If I remove the throttle cable from the linkage with it locked in neutral I can move the cable back and forth 1"
1" of slack??
