Re: Mariner Magnum 40
Hi Bro!<br />My engine got an electrical choke. I just push the key on the starter and hold it there when I turn the key and cranck the engine. Hence I do not have a manual choke switch or button under the hood.<br />It used to be autolube, but that system is blocked and the great big oiltank in the front are removed.<br /><br />Chris!<br />After I put on the fuelline - the right way this time, the engine is almost starting. It fires, but Im not sure on all cylindres. The starter re-engage when the engine pick up speed, but it stalls after 1-2 sec. Thick smoke is coming out of exhaustports.<br />The upper carb is dripping fuel when I pump the bulb. Maybee the lower one leaking too, but it could come from the upper carb leak.<br />When i open the throttle and look into the lower carb, I can see some "gasket stuff" used as a sealing between the carb and the motorblock has been squeezed out in the intake.<br />The fuelfilter is empty when I have crancked the engine for a while and the bulb is soft.<br />My guess is the fuelpump or some airleaks in to the carbs when operating. I will rebuild the fuelpump and the carbs.<br />I have to go to work friday morning. Then I go to my mountain cabin on sunday to do a lot of preplanned maintainance before the winter comes.<br />Next weekend I go salmonfishing with my brother (wouldnt miss for the world)And then I go to work for a week. My next chance is mid august, which is a pity. I really got a lot of good help in this forum, especially from Chris. <br />Thanks a lot!!! As a former actor and now a governor in a sunny state in the US once stated - Ill be baack!<br /><br />All the best from Paul
