Maybe my turn for new boat time
alldodge
Pics
Will post others later after resize
alldodge
Boat has sat mostly for almost 2 years. Measured the Bats and start was 12.7V and house 12.2V so plugged in charger. Bats are Odyssey Extreme so seeing if both will come back up (should be 12.9V)
Also missing the little air pump used for winterization. I'll contact them after letting the Bats charge for couple days, Bats might come back. Might even just buy the pump, it's about $20 something
The boat came out of the whole slowly but that could have been the salesman. Did notice with drive all the way down it's not tucked in even with transom, wonder if Formula installed blocks inside the trim rams?
alldodge
Boat steering is stiff, Formula is checking into it but says it doesn't have power steering but has power assist. I mentioned that the steering is about the same with the motor off as well as running. Never seen one as stiff.
Hey @muc have any idea what would cause the new steering to be hard to turn, fluid was checked and it's full?
Pmt133
Just out of curiosity, well 2 actually.
First, what air pump? Is this like a quick winterizing kit?
Second, what kind of rack is on the helm?
Pmt133
Oh, so bicycle pump.
I only ask as I tried one of the no feedback Helms on my restoration and hated it for the same reason. Stiff. Stiffer than the 40 year old detmar it replaced. I don't see why they'd use that on a power assist anyway, but just a thought.
alldodge
Good point
I could use 1 of my bicycle or B-ball pumps to do the same thing.
Looking at the parts for the so called "power assist" it's the same parts many cars use so it should work the same as self contained unit
