bassrascal02
Thread starter- Joined
- Jul 22, 2010
- 17
I recently rebuilt the carbs in my 94 Merc 115...and took it out today for the first time since the rebuild. After working with the low speed idle screws on carbs 1 & 2 I felt like I had the idle settings about right so I tried the mix in gear. Engine kicked into gear a little hard but not more than before the carb rebuild, but then when I tried to jump on the throttle to check a simulated hole shot the engine bogged and shut down. After trying a couple more times the engine would do the same bogg down and the seem to JUMP into higher RPMs. Nothing smooth about the transition. Do I still have work to do to link & sync my carbs correctly or am I seeing a problem from somewhere else?
Thanks
dr
Thanks
dr
