Merc 3.0 not getting fuel at 3/4 tank
chadnort
SAM_1329.jpgSAM_1331.jpgMerc 140 3.0 SN 6903513 1985 Searay Seville 5M. Boat ran great today until it stopped getting fuel. I filled up the 20 gal tank before going out but after running about 5.2 gallons (from the gas pump later) NO FUEL. Carb dry, fuel filter empty. After fillup ( and a long tow, UUGH) motor purred on muffs in my yard. I assume there must be a hose inside the fuel tank that has failed or the pump in there is FUBAR. Any one with ideas? I attached a photo of where I think the problem is (fuel tank) and encourage any help, thanks in advance. CNort
fmalott
Re: Merc 3.0 not getting fuel at 3/4 tank
yes take your check valve out the line inside the tank is probaly cracked and sucking in air the line is just plastic i just replaced mine last week i had the same problem very easy to fix
Jmunk
Sounds like the anti-siphon valve is fubar, or your pickup in the tank is clogged/obstructed.
Don S
The anti siphon valve doesn't have anything to do with fuel level. The pickup tube on the tank is probably loose or fell off.
chadnort
Here is a photo of what was in the fuel tank. This hose is about 3 inches long and the bottom of the tank is about 8 inches deep. Maybe there was another hose zip-tied on there at one point? This job is best done WITHOUT a FULL gas tank!
P.S. pen was added for reference, it was not in the gas!
chadnort
The more I look at my "fix" the more I think I should go to the parts store...
Say Don, I just noticed your link thank you!
fmalott
well it's not the greatest fix but the plastic has to resist gas i'm not sure if zip ties are resistant
chadnort
:DYea, rather than fish various plastic parts out of my tank, I went ahead and ordered a replacement. Glad to have addressed the problem with minimal cost/time. Thanks for helping me figure this out!
