Gibbles
Thread starter- Joined
- Nov 14, 2009
- 2,050
Re: Merc 65hp on a Jet Star?
Little update
I was got the little Clinton engine running, but the inline fuel pump does not seem to be working as the engine cuts out after a short time.
So I have two choices right now, find a lawn mower fuel tank and let gravity help, or replace the fuel pump.
I found that several lawn mowers have the same type of fuel pump as do some scooters and go-carts.
And on the Merc 65hp.
I got everything back together, and jumped it off of my car battery...
Fired right up and ran for a sec and then died.
After that it would not start back up, and it had a weak/intermittent spark
After some ts I found that the engine harness plug had a very bad connection, and I decided to cut it out and spliced the wires in directly.
After that the engine started right up and runs great
I let it idle for a bit in a water tank, saw a weak pee stream, held my hand on the engine and it never got very warm, so I was thinking it was related to the thermostat.
let it run for about 8-10min and the pee stream never changed, and the engine/heads never felt hot to the touch... so I decided to jam the plastic whip from a weed wacker up the tube and after that I got a good 3ft stream...
I will run some more tests on the engine before I decide to mount it, but I have to get a new bucket first as gear box put it self in gear a few times and the torque turned the engine right into the side of my garbage can, and splashed me with about 5 gal of water.
and my bimini top came last night from iboats, looking forward to some nice fishing this weekend.
Little update
