Huron Angler
Thread starter- Joined
- Apr 7, 2009
- 6,025
This Mercury came with this boat when purchased used and I've got a few questions about it. I will get the serial number to confirm but I am curious of the ballpark year.
The HP is unclear since the front cowling has 45 while the lower unit shows 50. I'm assuming the 50 is correct due to its location.
The 2-cycle oil pump went and we were told that it cannot be replaced with a new one for some reason due to the motor's age. I'm not convinced that is true. Mixing will work in the meantime though.
This is the oil reservoir and pump that just went bad recently
You can see the conflicting HP numbers in this view, not sure if the front that reads 45 was a replacement from a different motor or what. PO is not available to ask unfortunately.
