So I recently got ahold of a 70’s merc 1350 and when I went to look up the serial, it happens to be about 70000 off from the highest that serial set went. A couple other components are odd such as the fuel pump mounted like a side component like they did with the mid 70’s 1150 and 1500 went to rather than the block mounted double pumps. Plan to dig under the cover more today. Is there another way to determine if this is a different engine loaded on a 1350 body other than the serial? Lower does have the double stud through the cav plate that the 1350 would have before the 72-73 switch to single stud. Serial plate doesn’t have engine size on it like my 650 did. Thanks for any help. Still plan to use it, just wanting to know what I have.
