merc to evinrude-need advise
wedge542
current pontoon with a 115 mer 2 stroke,,,found a 1986 200 evinrude nice deal,,any problems known with this motor,,,are the 200s 4 stroke,,,,how much does it weigh,,,,,about how much faster would my pontoon be with this 200 vs merc 115,,,,thanks evinrude guys.
tx1961whaler
Re: merc to evinrude-need advise
A 1986 Evinrude is a 2-stroke.
What is the HP rating on the boat?
Motor is 380 lbs (no tilt/trim)
o/b tech
Good motor and what is the make and model of the pontoon? Have you had an inspection on the motor to make sure that it is in good running condition?
A quick off the top of my head guestimate with my calculator says around 20 or 25% faster at top speed, there are really too many unknowns to be more accurate, especially with a pontoon. One thing that is fairly certain is that at full throttle it'll burn nearly 75% more fuel per minute.
wedge542
pontoon is a 30ft tritoon,,,transom was installed with very heavy duty setup in mind,its attached to middle toon,,,extra bracing under rear,so it being a 2 stroke id still be mixing oil and would prob be as loud as this 115,,gas consumption will be a factor i see,,,are these expensive motors to keep up,build if needed?
Faztbullet
1986 was the small bore(2.7) bridgeport motor, they wont idle worth a crap no matter how much carb tinkering and brass you throw at them and love fuel. If you going to go white stay in the 93 and above years. A 60? 175 is the best bang for your buck on that toon...
wedge542
fazt,you got any in up there yet?
Faztbullet
Only things around right now is the 200ef'si and 250xb we talked about. I have a lead on a 90 model 200looper that needs a lower for $1900
