MerCathode System
brokemerc
Hi, I hope this is the correct forum for this question. I own a 1995 Bayliner Capri 1854 3.0 I/O,, previous owner cracked the block on a brand new 3.0 engine. I just picked up a used complete engine which appears to be in very good shape my quesion is that this engine has the mercathode system installed, or rather the controller not the annodes ect. I will be operating my boat in saltwater but it will be completely washed and rinsed after every use and kept indoors, do I really need this mercathode system????
jollymon
Re: MerCathode System
No you do not need the MerCathode system, if you are keeping your boat on a trailer.
The MerCathode system is to prevent galvanic corrosion while you are in the water. The galvanic corrosion is caused by problems, with shore power connected to boats at the dock.
brokemerc
Great, just thought I'd make sure.
