sutor623
- Joined
- May 23, 2011
- 4,089
Hey guys I have a little issue with my control unit. It is a MerControl from the early-mid sixties. In the Seloc manual it is described as the "early" version of the shifters. There is a shift/control handle and a neutral throttle lever. The shift lever shifts the gears into F-N-R with no issues at all. When the motor is started, the neutral throttle lever controls the idle very well. When I push the main control lever further into F or R, the idle does not change at all. Does this mean that I have a throttle linkage issue? I was wondering if the main control lever controlled the gears as well as the throttle for this series control box. Thanks as always guys!!
