Mercruiser 140 I/O help
Kootenay
I have a 140 I/O mercruiser and I need to replace the prop shaft seal. Are there any special tools needed for the job. Sure can use some feed back on this.
achris
More fish than mountain goat
Re: Mercruiser 140 I/O help
You've going to need a cover nut tool, a press, and the manual. And depending on whether it's an Alpha or 'pre-alpha' you may also need the drive shaft bearing retainer tool.
Chris........
