johnkom
Thread starter- Joined
- Jul 26, 2004
- 181
New engine two seasons ago and it runs great. But on plane, 2500 rpm plus, it starts to overheat. Temperature creeps up slowly into the red until I throttle back after about 3 to 5 minutes. Then engine cools down to normal and you can run all day off plane never heating up. I have replaced almost everything in the cooling system. New manifolds and elbows. New outdrive pump and water pocket. New outdrive water pump hose to stern tube. New marine engine water pump. New thermostat. Removed thermostat to trouble shoot and still same symptom. All temperatures verified with two different IR temp guns. Bore scoped outdrive passages and engine hoses and saw no restrictions. Engine timing checked. Compressions all good. Don’t know what else to check. Ideas??
JK
JK
