crazyboutamercury
Thread starter- Joined
- May 13, 2009
- 9
First time out this year my 165 temperature went to 220 degrees on the guage. I idled back to the ramp to load up with no issues or what seemed like excessive heat. I removed and replaced a defective impeller and thermostat and put the boat back in the water. The boat seemed to have low speed surge issues but ran out fine never getting over 140 degrees. At idle the normally smooth 6 ran rough so I loaded up and pulled the plugs for a compressiio check. Noticed adrip of water from gasket between intake and head and found water in #6 cylinder with head removed. Cleaned and checked flatness of head. Found intake and exhaust ports of manifold holding water. Drained water, replaced gaskets and ran engine from hose. Startup was fine and sl;owly transitioned to rough idle. #6 plug found wet with water coming from plug hole when cranked.
Is it possible to damage the manifold with low water (bad impeller) and get water to leak from heat exchanger into intake and back cylinder or did I miss a crack in the cylindetr head?
