Mercruiser 3.0 No Spark issues
nola mike
With the lower shift cable disconnected I can shift the drive by turning the shift boot with my fingers yes
Turning the shift boot? I'm saying take the cable off and move it in and out by hand
The water was leaking through the trim hose area while the motor was off. It's possible I disturbed the gasket for the trim manifold while doing all this work? If that is likely I can reach the trim manifold gasket
Water coming into the boat or going out?
After fiddling with the shift cable and redoing my adjustment again it appears that issue is resolved. I can get FWD, neutral, reverse all out of the water. Prop locking how it should.
However, the shift interrupt switch is not being actuated how it should.
Again, disconnect cable and try shifting manually. Should be K-Y smooth. That will tell us if it's the cable/drive or an adjustment problem.
To me it seems that in reverse the shift interrupt is always active, and when shifting to forwards it does not move at all.
It shouldn't move at all with the boat out of the water. If it's moving like you describe, that suggests a cable problem.
aidanmurphy
Thanks Mike, I misunderstood what you meant by disconnect the cable and try, I thought you meant to actuate the shift boot manually on the drive.
Water into the bilge where the trim hoses come through the transom. A significant steady stream.
With the cable disconnected moving it in/out by hand, it is extremely smooth and no binding. The shift interrupt switch is in the "kill" position with the throttle in reverse. Seems like I have just adjusted the cables incorrectly. Will dig into this more. My main concern at the moment is the leak
dubs283
If coming from the bottom of the gimbal housing it could be the gasket for the trim hose manifold block mounted to the bottom of the housing (exterior side), transom seal gasket, or lower through bolt/anode assy (if equipped). If dripping from above could be y-pipe seal, bellows, etc....
nola mike
On muffs I think has to be y-pipe itself or hose from the transom if not from the engine or other hoses.
aidanmurphy
While I am waiting for my trim manifold kit to show up I have been reading more and saw that a good way to test the seals on the drive is to pressure check them. The only slight concern I have is that the yoke seal got kinked during install. Would this be caught with a pressure check?
nola mike
Yes. But did you find the leak?
aidanmurphy
I put the boat in the water and did not start the engine and went searching around with my hands, I was able to stick my finger in the passageway the trim hoses come through and feel the stream of water. I looked with a camera and the water is 100% coming only through the thru-hull where the trim hoses are. My understanding is that this would be related to the trim manifold? Please correct me if I am wrong
Correct
aidanmurphy
Did you guys fab up a pressure checker or buy one? I found one online but it's a bit steep at $160
nola mike
Yes, your earlier posts suggested that it leaked on muffs, which wouldn't be the trim manifold
I use a piece of hose with a schrader valve clamped on one end and a gear oil fitting on the other. Use a bike pump and gauge to measure. Plenty of fancy ideas if you search on here, but mine works.
aidanmurphy
Thanks I will try something like that. Sorry for the misunderstanding, I did not hook the boat up to muffs, I have a ramp in my neighborhood so I usually just trailer it down real quick for a test. But it is leaking there with the motor off. Will replace trim manifold later this week hopefully and test
achris
More fish than mountain goat
aidanmurphy
Does it matter if you apply pressure via the vent hold or the fill hole? I have an adapter I could use to apply pressure via the fill hole but not the vent hole.
aidanmurphy
Small update, I ended up pulling the drive back off and ordering a different alignment tool. Turns out the original one I was using did not actually slide all the way into the coupler because of a design flaw. So glad I did that, aligned the coupler and got pretty even grease on the tool. Slid in easy with two fingers. Drive went back on like a charm.
Still have an issue with the trim manifold, I replaced the manifold and the gaskets and there is still a pretty steady stream of water coming in through the trim hoses. I can stick my fingers next to the hoses from the inside and feel the water stream. Could someone point me to a diagram of how the manifold and gaskets go together? Any potential leak areas to check around the manifold? Not sure if the transom could leak through that area and it's not the manifold itself. I did take a screwdriver and push around on the transom from the inside below the trim hoses. Didn't seem like it was budging any
Water is coming in on the inside around the trim hoses, most likely the exhaust manifold is cracked of the transom assembly is cracked
There is only one gasket and pretty simple how it goes together
aidanmurphy
Neither of those sound very good.. This is with the engine off, not sure if that would make much of a difference in the exhaust manifold. I am thinking it might be the transom as this leak got a lot worse after I pulled the drive, maybe I jiggled it around and made it worse. This is a mediocre video of the leak.. Anything I could try to troubleshoot this, tightening transom nuts maybe?
aidanmurphy
