Mercruiser 4.3 gas smell from air intakes
aamichiganfan
I just had a new engine installed last year, and now I am smelling fuel from the air intakes. Is this ok? It makes the whole boat stink of gas.
Re: Mercruiser 4.3 gas smell from air intakes
Ayuh,... Welcome Aboard,... You'll have to be Much more Clear with your explanation...
What intakes,..??
Got a Vintage,..??
Carbed motor,..??
Bt Doctur
If you mean the intakes on the hull and not the air cleaner then
YOU HAVE A GAS LEAK SOMEPLACE
aamichiganfan
There are 2 air intakes on the back sides of the boat that draw air into the carborator (I think that's where they go). I don't see gas leaking on the outside of the engine, but I smell it from those intakes. it's an 87 ebbtide riviera with a 4.3l mercruiser and a 205 carb.
Don S
It's very simple, you have to find the leak.
It could be anywhere. Carb or fuel pump could be leaking if someone put a non marine part on it. Lines, fittings, on anything, or even the gas tank itself. I have replaced many that a hole corrodes through.
But you must find it. An enclosed area with fumes is an explosion waiting to happen. All it takes is a spark.
Ayuh,... Gasoline is a Heavier than air vapor, in collects in the bowels of the bilge,...
Til it finds that Spark,..... BOOM ! ! !....
