nola mike
- Joined
- Apr 22, 2009
- 6,119
Oh, gotcha. Looks like everybody was thinking that was relative/gauge value. Not sure what "arbitrated" TPS means? Is it drive by wire system? Also, looks like these values are at steady state conditions rather than WOT (otherwise demand should be 100% the whole time)? In other words, if you have it floored, does the TPS and demand both = 100% through the rpm range? When you hooked up a manual gauge, is that 13" steady? Lastly, your timing is (I think, LOL) going the wrong way. 29' at 3k, 19' at 4300.It does but too much imo. Vacuum is not shown directly. Vacuum is a difference between barometric pressure and manifold pressure. At WOT they both read nearly the same as you would expect but it's very low at 3000rpm when throttle demand is at 58.2% but arbitratted throttle position only 21.4.%. Got a feeling that engine is unable to create enough vacuum and PCM closing throttle to keep RPM steady.
See his reply to me...those numbers are absolute manifold pressure.Maybe I missed it but thus far i haven't noticed 12.9inHg in any of the screenshots...Saw 17.2 under Manifold pressure at idle of 6.22 RPM?
