mercruiser alpha coupler assembly problems
mend212
my coupler assembly burned out we replaced it went out on the water and it burned out again. does anyone have any ideas what could lead to this problem?
Alumarine
Re: mercruiser alpha coupler assembly problems
It would be better to post this in the Mercruiser section.
Did you align it when you changed it?
How are your stringers?
mend212
guess i posted in the wrong section. but since ur askin no we didnt check the alignment and today when we took it apart we were wonderin if that had something to do with it. so i assume alignment is pretty important?
mend212
and if u mean stringers of fish.....we were at laguna madre for just a few hrs and we took home a 20 in black drum and 2 16 in gafftops!
mend212
btw the drive stringers are fine.:D thanks for ur input!
bigskiohio
alignment has to be on and the rear mounts are rubber that may break away from itself so pull motor and check your rear mounts and align,should slide on easy to about 1/8 inch. bar should slide in easy. repost in the right section if you need more help.
