IanFS
Thread starter- Joined
- Apr 21, 2009
- 188
Hi all
I have a 1988 Sea Ray Seville with a 4.3L V6 Mercruiser. Sadly one of the front engine mounts has rusted away on the bottom plate so time to replace. These are the old type of mount.
I've done the usual Googling for a replacement pair but can only find HGE aftermarket here in the UK. Trouble is the website I'm looking at doesn't specify which model they are for, but merely gives a weight they will take which is 160kgs with a 16mm stud. Here..........
https://repowermarine.com/index.php...exible-engine-mount-160kg-with-16mm-stud.html
So I've checked through the Mercruiser PDF Manual I got from here a few years back and can't find the weight anywhere.
Any help would be very much appreciated, even if it meant I try to get a couple from over there in the US.
