Mercruiser fuel pressure gauge hook up - 454 MPI
77_starcraft
how can I measure the fuel pressure on my 1998 454 MPI. there is a port on the front of the engine with a schrader valve. what fitting do I need to connect a fuel pressure gauge.
boat will fire but not run or idle.
dubs283
Re: Mercruiser fuel pressure gauge hook up - 454 MPI
is the safety lanyard properly in place?
you need a fuel pressure guage that has a schrader valve end on it to measure the fuel pressure
77_starcraft
yes the lanyard is in place.
the fuel test port is larger than a tire style shrader valve. where can I get fuel pressure gauge that will work with this port?
the pump will run when key is cycled. I got about 4-5 oz of fuel from the return line from cycling the prime 12-15 times.
It looks line I may be able to 't' into the rail supply as they are flare fitting instead of that handy test port. no fun.
Fun Times
You can get then from sears, napa, ect, http://www.harborfreight.com/cpi/ctaf/Category.taf?CategoryID=455&pricetype=
77_starcraft
thanks found one at autozone. got a filter wrench while I was there.....
pressure was fine it was the water separator that was full of water that keep it from running.
all good now thanks..
DOOH!
