mercruiser gimbalhousing inner and outer bolt torque specs?
sidingguy
Any torque specs on gimbal housing to outer housing? Or does everyone just tighten them down 2 turns past stripping?
Bt Doctur
Not sure what your asking, the 6 drive mounting nuts or the hinge pins?
Grub54891
50 ft pounds. That would be with new nuts, and studs that are in good shape. If they are wore out, they will give an incorrect reading, overtighten and squish out the gasket. you can re-use the nuts several times, but I "feel" how they are turning when removing and installing, and replace as needed.
Bt Doctur
They are Ny-locs so just nice and very snug. No Gorilla force neded
Sorry,I meant the 6 mounting bolts.
Ayuh,.... They are chrome plated brass ny-lock nuts,..... 50 ft.lbs. is the stated torque value,....
I just snug 'em to "Good, 'n tight" with my calibrated elbow,.....
Fun Times
Just so it's a clearer, safer picture here, one of your other posts suggest you may of been pulling the engine and Transom Assembly out of the boat as you mentioned;
Leak at bottom of bellhousing is wait for it ROTTEN TRANSOM!!! Bottom 3 inches is mush. Filled bilge with water and it leaked out around gimbal ring. Looks like next post will be in Restoration!
So with that you'll want confirm the terminology of the components with the help of the following guide, http://forums.iboats.com/forum/engi...-safe-search-version-of?p=4138463#post4138463
If you happen to be reinstalling the Transom Assembly to the inner transom plate on the inside of the boat then the torque would be 25 ft.lbs.. http://www.mercruiserparts.com/bam/subassembly/30872/2203/40 ...... http://www.mercruiserparts.com/bam/subassembly/30872/2203/20
