Mercruiser outdrive identification
Pikey23
My wife and I bought a 1984 fourwinns this year with a 3.0L 140 mercruiser, I can not identify what drive is in it though. I pulled the drive today after winterizing the boat so I could check the gimball bearing and u-joints. I have been told that it is a pre-alpha, a alpha 1 gen 1, and a MR. I really have no idea and would like to get some parts. The number stamped on the upper unit is A422131 the transom assembly serial number is A406605. Any help would be great. Thanks
Bifflefan
Re: Mercruiser outdrive identification
That is correct. They are one and the same.
There is not really and A1 gen1 per say, but if its the original one its an MR.
83 was an R and 85 is an actual alpha 1.
Pikey23
So do the MR and A1 basically use the same parts? I need u-joints and a gasket kit to remount.
thumpar
I would change the impeller also unless you know for sure it was changed in the last 2 years.
Bifflefan
Check out this link.
I just reread the history and I made a mistake. 83 and 84 are "R" drives 85 is a "MR" and 86 on is Alpha 1.
"R" meaning Redesign
"MR" meaning Mercruiser Redesign
Ayuh,... That is Correct...
