So, When I turn the key the starter spins (sounds like a whiiiiine) but the engine does not crank. So the starter is not engaging the flywheel? Does this mean a new starter? anything else I should try/culprits to look for?
Things I have tried:
(Mercruiser 1994 Alpha One)
Gages work.
Battery is good, even swapped it out to same result.
Disconnected all battery connections, slave and starter solenoid connections, brushed them and re-tightened.
Jumped from the battery to the small terminal with yellow wire on the slave solenoid and got the same result.
Jumped to the big terminal, got some sparks and same result.
Any help appreciated!!
Gages work.
