25thmustang
Thread starter- Joined
- Mar 20, 2008
- 1,849
I just picked up a project boat and the trim isn't working. Got the pump/motor all cleaned up and bench tested and now it's on to the cylinders. As luck would have it both cylinders were "locked up" in the trailer position. I got one apart and free to rebuild, having trouble with the other.
I'm most likely buying new however am finding some cheap used cylinders (I may use to test the system). Are all alpha 1 gen 1 cylinders the same (I have a 5.7, would a 3.7 cylinder work?)?
Thanks!
Thanks!
