Re: Mercruizer Alpha 1 3.0 sluggish..extremly when under load
Once it's dropped into the water and in gear, it will drop about 50RPM, but 800 is still too high. Follow the procedures and specs achris is posting up, very good info there...
Work on getting the idle RPM down to where it's supposed to be, then check your timing again. If it's still way off, then worry about the balancer slipping and the timing mark being off.
I tighten the alternator belt really tight, pull all the plugs, then use the big nut on the front of the alternator to turn the engine over using a ratchet,,,, if rocking the engine a breaker bar works well.
Engine is idling at about 800 or so
what is the best way to hand turn the engine to find TDC?
