travisb5470
- Joined
- Apr 3, 2014
- 15
Re: Mercury 150 xr4 no spark. Any thoughts?
Ran jump test the motor went down from red to green and didn't red to grn/wht. So J solenoid is bad? How do you get to the bolts to take them off? they are behind them. Thanks for the knowledge!!! Great schematic!
See imaged below for/if "Three Wire" setup with no response from switches.
Ensure 12V is present(and stays present during following tests) at down solenoid(j)'s red wire STUD (not ring lug), If trim motor is going up, then it and ground(shared) are properly good but check/monitor it's 12V anyway.......Ring lugs can be/get flaky even at the crimp sometimes eh?
Do test #1 first,
Test #1
Goes down?
Yes.......if it goes down, proceed to #2.
No........motor/motor wiring
Test #2
Goes down?
Yes......check 12V feeds to either the engine cowl switch(g)(and fuse "e" if equipped) and/or trim switch(d)
No........check solenoid's coil ground wire, if good.......*Replace Solenoid
***Solenoid's coil typically open if no "click" is heard during this test or Solenoid's contacts typically bad/burn't if "click" is heard during this test***
All JMO of course :lol:
I best go hang a motor, ice out smallies are call'n me........:fish2:
