Mercury 150 XR6 Tilt/Trim Problem
smitty21
sometimes the tilt works, sometimes it wont, sometimes it tilts up or down on its own as soon as I add battery power. I am stumped about this problem. please help. Relays are brand new.
JUSTINTIME
Re: Mercury 150 XR6 Tilt/Trim Problem
check your relays on the engine
sounds like bad connections or relays going out
smitty21
JUSTINTIME,
Thanks for the advice, unfortunately I have already tried it, purchased two new relays and swapped out the ole relays. Still same problem.
JUSTINTIME
now u need to get a meter and test for volts
blue is up
green is down
smitty21
Not sure I am following you? Blue and Green from the relays?
JUSTINTIME
yep
pull the relays
test blue for 12v when u push the trim buttom up
green for down
