Mercury 50..how old?
timscooby
have aquired a mercury 50 non starter! need to order some parts to repair only cant find a tag on it for serial number. Do they come off or is it stamped into the engine? Its 3 cylinder,electric start,with a blue band around the cover.
north40
Re: Mercury 50..how old?
Tim,<br /> See if you can find a welch plug (freeze plug)<br />with a number stamped on it. It should be on lower rear. Ser# are listed here on many engines. The tilt tube in front of engine or on rear of transom bracket are places where serial plates or stickers are located but may get removed or painted over. I think your engine is most likely 86-88 but only number will tell for sure. If you find number, post it and we can work from there. Good luck<br />Bob
timscooby
thanks for your reply bob, will have a look the weekend then report back what I found!
timscooby
well had a look around and these are the what I found....A green sticker with the words o.k<br /> oc 87<br /><br />and various numbers 1025- 3506-37496 or c <br /> A8363 <br />89 DLD 1593<br /> -7511<br /> -02 allso its not only a blue band their is allso a thinner red one as well<br /><br />thanks in advance to any replys<br /><br />Tim
Moody Blue
Those numbers don't look relevant. The welch plug is about 2.5cm diam and will be on the block of the motor somewhere. It is not a sticker but is pressed right into the block of the motor. Usually well hidden :rolleyes: .
Mercury140-I6
If it's a blue band cowling, and no one has changed it, then it is somewhere between 73 and 79. Only the serial # can narrow it down further.<br /><br />Craig
timscooby
cheers craig but I made a mistake and ive noticed it had a thinner red band above it as well. Will insert an image whend ive worked out how to do it<br />cheers<br /><br />Tim
timscooby
hi guys<br />have found what could be the welch plug with the number B173969 stamped into it...have we cracked it?
north40
Tim,<br />We have found it...1987. Good luck,<br />Bob
timscooby
thanks guys,but dont go into hibernation just yet. complete novice going to attempt impeller change....<br /><br />Tim
