mercury 50 thunderbolt ign help
mercuryme
please help i am in the uk seeking help for my outboard mercury 50hp blueband thunderbolt ignition
firstly i would like to know the age of the outboard serial no, 9233982 secondly i was told it was the stator playing up and when i took the flywheel off and stator the stator plate has a crack i will discribe the plate which the stator screwed on to by 4 screws and then there are 4 bolts i have taken the bolts out but the plate does not want to come off whether its stuck i dont know or whether the engine has to be taken apart any advise will be greatfull and thank you for looking my email address is sgf_1111@yahoo.co.uk
tashasdaddy
Re: mercury 50 thunderbolt ign help
please recheck your number. can't find.
mercuryme
hi and thank you for your help all i have is serial no, 9233982 on the outboard bracket chassie no, 14807217e on the head 1017-6636 hope this can help you more in helping me, shane
05GlastronSX
i believe the engine is a 1978 model 4 cylinder.
mercuryme
yes you are right it is a 4 cylinder i should of stated that
now i need to know about the stator bracket
mercuryme
stator mounting cracked what do i do
tashasdaddy
DOUBLE POST. KEEP YOUR POST IN ONE PLACE!!!!!!
mercuryme
still no news on my brackett that hold the stator on i have undon the 4 bolts does this lift off with force
also the number on the stator reads 0404 stamed on it with heat and no, 398-5454a21 stamped on it with white print, i am asking these questions as i have brought a boat with engine but the engine does not start and there seems to be that the engine is too cleane to be true
Laddies
Banned
Mercury has a flat plate puller that fastens to the upper main brg cap which is what your trying to remove in some cases if you loosen the top 2 crankcase bolts on both sides you can tap it and get it to turn, with a couple of screws in the screw holes it will pull up as you turn it
mercuryme
what does a main brg cap is this the right name for it if i asked for one at a dealers, and thank you for information as i am doing this engine from no knowlage at all just so i will know the engine back to front and maybe if all goes well help others
Laddies
Banned
mercuryme, goto the BAM Marine site they have parts breakdowns on Mercury engines and the proper names and part numbers
