Mercury 850, need serial group help for parts ordering.
adamjr
Hello all,
I was hoping this info would have been in a sticky so I propose if someone has the answer that this be added as a sticky.
I have a Merc 850 serial number 4539450. Depending on the source it is either a 1976 (Maxrules) or a 1975 (Marineengines). What I can not find is the serial number group.
In the parts breakdowns for the gear housings it is divided into either Serial Group 1 or Serial Group 2. The water pump housings are different part numbers. I would rather order the parts (whole kit including housings) rather then open it up and decide what I need then. I am trying to take the same approach as I do with a car if I am replacing a timing belt. If I have to take the water pump off and there is a lot of work to get to that point of disassembly I would rather spend the few extra bucks and replace it now then later.
So how do I know what my serial group is? I googled it and only found what i had already found which was that there are 2 serial groups, nothing about how to know which you have.
I was able to start the motor yesterday with very little trouble. Ran it about a minute but nothing out of the tell tale. I am going to fog it today before the Bears-Chargers game and put her to bed before the winter. I'm going to order my needed tune-up parts over the winter and do the repairs first thing this spring. She needs at the very least an impeller, all new fuel lines, at least 2 spark plug wires, a fuel pump repair kit (leaking).
Any help will be greatly appreciated.
Thanks,
Adam
carholme
Re: Mercury 850, need serial group help for parts ordering.
Your s/n comes up as:
85 850 4-cyl 4366802 4590511 1976 USA
From here:
http://www.marinshopen.se/Motorer/O...Mercury2takt4cyl4085hp/tabid/487/Default.aspx
As you already have the parts listing, here is the 850 Serial Group chart. You choose the serial group which yours fits and as for the gear housings, they have groups 1 and 2, yours would be serial group 2 for engine s/ns 3865695 and up.
http://www.crowleymarine.com/mercury-outboard/parts/461_220.cfm
Gerry
