Mercury 900 rotor removal
Re: Mercury 900 rotor removal
If you are talking about an early to mid-70 Outboard motor, the rotors are non-removeable. They are one piece with the rotor shaft.
Sorry, the forum bleeped out the site....Just tell me year and HP, or serial number, HP and num of cylinders.
CharlieB
mercruiserparts.com/mercruiser_parts.asp
Stick this in your address bar, then search with pictures
Have your model and serial and see exactly how your dist goes together
That Dist shaft and rotor is one-piece and No Longer Available, if or when you do find one, it is going to be expensive $$$$$
Faztbullet
what is the easiest way to remove the rotor without damaging it??
Find a old Merc shop or Ebay for a set of rotor puller pliers Merc part # 91-32477A1 as you should have the dual point/coil distributor, if it has been updated to a S/S distributor it is non removable....
