Mercury Serial Number
grbeasley
I have a 1994 Mercury Tracker 40hp outboard motor, serial number 0G100240. When I try to find my motor in any kind of serial number reference, it comes up as a 40hp 30 jet. Mine is not a jet. See below (copied and pasted). Can anyone explain this and maybe give me a link to accurate sn info?
Manufacturer:
Mercury Marine
Serial Number:
0G100240
Model Group:
40 HP30 JET
GA_Boater
I also get 40/30 jet in the places I normally look at.
Possibly it has been converted from jet to prop. It's happened before.
Is this a 2 cylinder motor ?----Any pictures of the motor powerhead ??
grbeasley
Ga Boater, I found this cross reference and it appears that the Jet 30 sn falls within the same range of others: see below under 40 1994 Jet30 and 40 1994 ELO and ELPTO. The search engines must stop at the first match.
401994JET 30G052645 - G116490 501995ELHPTOG117373 - G290584
401994ELO (Tracker)D279350 - G116518 501995ELPTOG117275 - G290584
401994ELPTOD279350 - G116553 501996ELHPTOG290585 - UP
401994EOD279350 - G116487 501996ELOG290585 - UP
401994MLD279350 - G116518 501996ELPTOG290585 - UP
401994ELPTO (Tracker)D279350 - G116541 501996EOG290585 - UP
401994ELHPTOD279350 - G118089 50 HP MODELS (4-CYL)
401994ELOD279350 - G116485 501963Short & Long1552535 - 1605951
401994MD279350 - G116789
GA_Boater
Your SN falls in the 1994 range, so any matches from the model chart? For example, ELPTO meaning electric start, long shaft, power trim, oil injection
GA_Boater
Solved - The parts listing/diagrams for your serial number covers both prop and jet drives.
