Mercury Smart craft assembly
world
OK first off, I guess I don't know what I'm doing thought it would be easier than it is. I bought a 1987 Boat with a 1986 Mercury 3-cylinder 2 stroke with trim and tilt, the engine is hurt and not going to rebuild. I found a 2003 Mercury 4 stroke EFI and would like to put on smartcraft, Called Mercury and they said this engine will work with Smartcraft but wouldn't supply me with any information on the items I needed said see dealer. Well, I went to the dealer, and I guess I wasn't clear enough that I have no gauges at all and would like the smart craft well I still couldn't get the information The boat has no gauge package on it at all nothing, does anyone know what I need to purchase for the Smartcraft gauges also this engine has an 8-pin connector. Than k you
tpenfield
It may not be all that simple, and I'm not sure how good SmartCraft was in 2003, as that will be you limiting factor.
It sounds like you need a Smartcraft 'conversion kit', but it may take some research as to which one. You will probably need a set of the Smartcraft gauges as well. It might be a bit of trial/error getting all the right bits. I am not sure if the dealers are experienced in Smartcraft conversions, rather than fixing existing Smartcraft systems.
What value are you trying to achieve? I have a new(er) boat (2016) with all the Smartcraft and Digital stuff . . . it only looks like fun. 🤪
world
I like all the items the Smartcraft can tell you about the running, but I need a tach and would like trim but getting other information would help oil pressure, temperature I see Smartcraft on eBay but I hesitate do to cost if it would work great no problem but to spend the money and all I have as a shelf item I have lots of those now
QBhoy
I’d think it be 50/50 if you’ll get smart craft from that engine. If you defo can. Vessel view mobile is the cheapest way to go.
