mercury
luckynickles
hey guys i have a 1989 mercury fiftyclassic is therea any shut down safety switchs on this motor besides water temp my outboard will not throttle up ive rebuilt the carbs check comp new plugs it still wont power up runs like 25 horse thnks luckynickles motor runs like a champ out of water
Jake.
Re: mercury
when you rebuilt the carbs did you check to make sure the timing was set correctly when you re-installed them?
Chris1956
Honorary Supreme Mariner
Re: mercury
I doubt that motor has a overheat shut down capability. Is it running on all cylinders? That is do all cylinders have good compression and spark?
444
Re: mercury
Mine was doing the same thing until I cleaned the carbs, set the float height properly, did a link and sync and new spark plugs.
You said you did the carbs and plugs, did you make sure to set the floats right and did you follow the factory procedure for the link and sync?
luckynickles
Re: mercury
i am not sure about the timing i dont know that much about them please explane
luckynickles
Re: mercury
how do you check the timing and what is link synk help me out here guys im not stupid i just dont know the lingo
luckynickles
Re: mercury
running on all cylinders i guess good compression on all and dont know nothing about timing
444
Re: mercury
Pick yourself up a service manual, it's all described in there. You'll also need an inductive timing light if you don't already have one. There are screws on the side of the throttle lever where you set the initial and total spark advance. It's part of the link and sync procedure, which is a set of steps to follow to make sure the carbs are synchronized with each other and the ignition timing. It's not hard to do, just follow the steps in the book. You'll need a helper to crank the starter over while you set the timing.
Jake.
Re: mercury
+1 to buying a manual. proper link and sync (timing) is a detailed procedure. not difficult, just detailed. you'll need a hard copy of the steps in front of you to do it with confidence.
