Milky gear oil mercrusier MC1
Blujay96
I pulled off my outdrive today because last year I was losing gear oil. The bellow had alot of oil in it. When I drained the lower case the oil was milky. I am thinking it needs the o-ring by the bearings. Were could the water be coming from. I read that the pumps can leak water in to the oil. I bought a new pump and impeller kit. What should be the next thing I should check. Thanks
Don S
Re: Milky gear oil mercrusier MC1
Was it milky watery oil in the bellows?
Blujay96
Somewhat. There was some milky and part looked more green
Don S
Pull the drive, drain the gear lube and pressure check it. look at the input shaft yoke into the drive. If you see any rust, you probably need a new seal and probably the yoke tool.
Oh, and replace the bellows, you also need a gimbal bearing and ujoints because it failed.
Blujay96
Thanks don very helpful as always. I have the drive pulled and apart. I will get the rest of the parts ordered.
