Milky madness
Jake222
So i was boating today and heard a noise like an intermittent foam cannon. Stopped the engine looked under the hood to find this. Engine was running great when I shut her off and got towed in. 5.7 v8.
Lou C
Looks like you blew a head gasket ou have a cracked head. Time to check compression and air pressure test the cooling system.
do you live where it got freezing cold a few weeks back?
if so, did you winterize?
Lou C
The GM small block is pretty robust, usually when this happens its either freezing water got trapped somewhere and cracked a head, intake or block or a past overheat weakened the head gaskets and you get water in the oil.
Salt or fresh water? Any overheats in the past?
Jake222
Fresh. Nope. Been running cool. It looks mostly like the sludge follows the whole seal of the intake. Cleaning now.
Jake222
I can only get it so clean with the carb and thermostat on. Removing the stuff. Gonna run a compression test right now then report back.
Rick Stephens
Need to do a couple oil changes.
I'd be worried from the look that the motor is pumped full of water from a crack --a manifold, the engine block or head--, all the same as far as filling the motor up and pooping oil water mix out the breather and onto the flash arrestor.
Jake222
Yep a few. Just pulled all plugs and they are all clean no sludge. Running compression now.
Jake222
All within 10 15 psi about 155 average. Looks good for what’s online. Gonna pull carb and thermostat to look at intake
Lou C
Before you start taking too much apart learn how to air pressure test your cooling system. The thermostat housing has to be in place to do this. In fresh water I doubt your intake rotted out, it happens here in salt but even so I’m still using my original 1988 intake used in salt about 20 years worth.
Lou C
Then how did you winterize it? There is a drain on each side of the block one on each manifold and you pull the lower end of the big hose at the front circulation pump. Each drain hole has to get poked with a pick or thin screwdriver due to rust flakes clogging the holes sometimes.
Jake222
What is gonna be my benefit from doing this?
Jake222
I didn’t say I winterized it just ran all the water out as in I had ran it every couple days for a few weeks leading up to the freeze in the driveway with no muffs for about 10-20 seconds. As I knew this would help with water removal.
Jake222
Also I am not 100% sure this motor wasn’t taken in salt water before I owned it.
Take the garden hose and connect it to the thermostat and let it run full force for a bit, to check for a crack. The oil pan will start filling with water or you will see water pouring into the bilge if there is one
isaacs
This may have blown some water out of the exhaust manifolds but would have done little to remove water from your block. There's also a good chance you've cooked your lower unit water pump impeller by running it dry.
