Min. clearance between prop and A/V plate?
XcellR8
Is there a minimum amount of clearance you should have between the tip of the blade and the A/V plate? If this distance is too close will there be heat or wear issues?
Texasmark
Re: Min. clearance between prop and A/V plate?
I have run as close as 1/4 inch and had no issues.
Mark
XcellR8
Thanx!
XcellR8
I just checked and 1/4" is what I have.
deejaycee_2000
The closest I have is 5mm (0.19 inch) on one of my motors ........ it runs fine
